Re: moped lost power and died - now won't start and has low compression
up shits creek /
> Ken Roff Wrote:
> > Den 23 Wrote:
> > > Nathan Kuebelbeck Wrote:
> > > Thanks everyone for the tips. Best way to get that stock bushing off
> > the
> > > small end?
> > Fashion a bushing puller tool.
> But then after you press in a new one you have to ream the new one to
> fit the piston pin with correct clearance her manual
> Without these tools and knowledge/feel that’s not gonna happen
> Even if you had the tools you probably screw up the first or second try
> y so your best bet is to get an aftermarket crank, one that has a needle
> bearing in it which is better anyways
> I have the tools and I’ve replaced them and I don’t like doing it I’d
> d rather rebuild a e50 engine with a new crank,
> The only time I really replace the bushing if it’s on a Za50 engine
> which is a lot harder to replace the crank
I was advised to get this one
https://www.treatland.tv/malossi-needle-bearing-p/malossi-needle-bearing-663973b.htm?fbclid=IwAR3HaGFM1fFKoWkJPYnMWCJvghR9UBx744V_uzi_PNa-zUMoSGi8v4FnnnU
  moped lost power and died - now won't start and has low compressionTopic by: up shits creek up shits creek 07/10/19 12:21PM
  Re: moped lost power and died - now won't start and has low compressionRe: Dirty30 Dillon Dirty30 Dillon 07/10/19 12:36PM
  Re: moped lost power and died - now won't start and has low compressionRe: up shits creek up shits creek 07/10/19 12:46PM
  Re: moped lost power and died - now won't start and has low compressionRe: Dirty30 Dillon Dirty30 Dillon 07/10/19 04:53PM
  Re: moped lost power and died - now won't start and has low compressionRe: live ɘvil live ɘvil 07/10/19 05:14PM
  Re: moped lost power and died - now won't start and has low compressionRe: Mike Boyd Mike Boyd 07/10/19 01:18PM
  Re: moped lost power and died - now won't start and has low compressionRe: up shits creek up shits creek 07/10/19 01:21PM
  Re: moped lost power and died - now won't start and has low compressionRe: live ɘvil live ɘvil 07/10/19 04:35PM
  Re: moped lost power and died - now won't start and has low compressionRe: up shits creek up shits creek 07/10/19 04:50PM
  Re: moped lost power and died - now won't start and has low compressionRe: Saabsonettguy . Saabsonettguy . 07/10/19 05:17PM
  Re: moped lost power and died - now won't start and has low compressionRe: live ɘvil live ɘvil 07/10/19 05:25PM
  Re: moped lost power and died - now won't start and has low compressionRe: up shits creek up shits creek 07/10/19 06:29PM
  Re: moped lost power and died - now won't start and has low compressionRe: Den 23 Den 23 07/10/19 09:53PM
  Re: moped lost power and died - now won't start and has low compressionRe: Overpriced Parts Overpriced Parts 07/11/19 12:27PM
  Re: moped lost power and died - now won't start and has low compressionRe: up shits creek up shits creek 07/11/19 05:44PM
  Re: moped lost power and died - now won't start and has low compressionRe: Mike Boyd Mike Boyd 07/11/19 05:48PM
  Re: moped lost power and died - now won't start and has low compressionRe: up shits creek up shits creek 07/11/19 06:30PM
