Re: moped lost power and died - now won't start and has low compression
Saabsonettguy . /
You can probably reuse the cylinder if you remove the aluminum smearing with a bit of muratic acid on a q-tip (follow safety precautions, its nasty stuff). You can probably also knock the high spots off the piston and reuse it as well. That said, stock top ends or 50cc kits are cheap. The small end connecting rod bushing needs to be replaced for sure. At this point I agree that it would make sense to go ahead and do crank bearings and seals. I'd probably bump your mix up to 40:1 as well. Get it back together and then get your jetting and timing dialed in to keep the temps under control.
  moped lost power and died - now won't start and has low compressionTopic by: up shits creek up shits creek 07/10/19 12:21PM
  Re: moped lost power and died - now won't start and has low compressionRe: Dirty30 Dillon Dirty30 Dillon 07/10/19 12:36PM
  Re: moped lost power and died - now won't start and has low compressionRe: up shits creek up shits creek 07/10/19 12:46PM
  Re: moped lost power and died - now won't start and has low compressionRe: Dirty30 Dillon Dirty30 Dillon 07/10/19 04:53PM
  Re: moped lost power and died - now won't start and has low compressionRe: live ɘvil live ɘvil 07/10/19 05:14PM
  Re: moped lost power and died - now won't start and has low compressionRe: Mike Boyd Mike Boyd 07/10/19 01:18PM
  Re: moped lost power and died - now won't start and has low compressionRe: up shits creek up shits creek 07/10/19 01:21PM
  Re: moped lost power and died - now won't start and has low compressionRe: live ɘvil live ɘvil 07/10/19 04:35PM
  Re: moped lost power and died - now won't start and has low compressionRe: up shits creek up shits creek 07/10/19 04:50PM
  Re: moped lost power and died - now won't start and has low compressionRe: Saabsonettguy . Saabsonettguy . 07/10/19 05:17PM
  Re: moped lost power and died - now won't start and has low compressionRe: live ɘvil live ɘvil 07/10/19 05:25PM
  Re: moped lost power and died - now won't start and has low compressionRe: up shits creek up shits creek 07/10/19 06:29PM
  Re: moped lost power and died - now won't start and has low compressionRe: Den 23 Den 23 07/10/19 09:53PM
  Re: moped lost power and died - now won't start and has low compressionRe: Overpriced Parts Overpriced Parts 07/11/19 12:27PM
  Re: moped lost power and died - now won't start and has low compressionRe: up shits creek up shits creek 07/11/19 05:44PM
  Re: moped lost power and died - now won't start and has low compressionRe: Mike Boyd Mike Boyd 07/11/19 05:48PM
  Re: moped lost power and died - now won't start and has low compressionRe: up shits creek up shits creek 07/11/19 06:30PM
