Re: Reusing speedo cable sheath / threads
Andrew B /
The speedo and drive are both CEV units. I've tested the speedo with an extra puch VDO cable I had lying around and it does work. The drive will definitely be gone through as I am sure it is gummed up. When I disconnected the old cable there was only one of the square end pieces on one end of the cable. I measured it and it was approximately 2mm in diameter. Are either of you aware of where I can find a cable like this? The autozone one doesnt include specifications for the inner cable end piece / core end diameter
Thanks
Andrew (edited)
