Re: 1976 Moto Guzzi Robin Carburetor
♣Slew Foot♣ /
I mean it works for what it does Regular ShA would work fine unless you can get it and have a better upgraded pipe that's compatible with the Sha I think you would be better off rejetting it and cleaning it and reset the timing if you have to buy a better atomizer for the one you have if you look in the wiki there are ways to upgrade the carburetor you have it just takes a little time and a little patience Moe's performance boost you'll get is if you decarbonise the pipe and the exhaust port put in new rings get it honed before you put the new rings in make sure you Gap the Rings properly make sure all your seals are good do a leak down test upgrade the intake and or reeds then the carburetor if you kit it...and get a better pipe.
