Have a Sachs Carrier and need to replace clutch cable. How do I dis-connect it from the clutch already have it off the hand grip. Second how does the throttle cable attach to the hand grip and third does anyone know the length of the cable for the rear brake, need a piece from the medal arm to the brake itself. Also anyone know were I can purchase the cables at.
Cables
Re: Cables
You can get away with using bike cables for the brakes, for the starter clutch cable you will need a prefab one. Probably the Spartamet front and rear brake cables will fit your cycle, Treats has those in stock... probably all the rest of the trusted moped parts place have it in stock as well, so just as a example:
https://www.treatland.tv/SACHS-super-special-STARTER-DECOMP-cable-p/sachs-starter-decomp-cable.htm
https://www.treatland.tv/sachs-spartamet-FRONT-brake-cable-p/spartamet-brake-cable-front.htm
https://www.treatland.tv/sachs-spartamet-REAR-brake-cable-p/spartamet-brake-cable-rear.htm
