Did you clean the points? Check the coil? You should be able to pull the kill wire outta your coil and get spark. I imagine that switch is just wired in between the kill connection and ground.
Subject | Written By | Posted |
Puch maxi ignition help!!Topic by: Anthony Sanchez | Anthony Sanchez | 07/04/19 04:46AM |
Re: Puch maxi ignition help!!Re: Stephen Keller | Stephen Keller | 07/04/19 07:25AM |
Re: Puch maxi ignition help!!Re: P D | P D | 07/04/19 08:26AM |
Re: Puch maxi ignition help!!Re: Anthony Sanchez | Anthony Sanchez | 07/04/19 02:08PM |
Re: Puch maxi ignition help!!Re: Aaron Blair | Aaron Blair | 07/04/19 03:25PM |
Re: Puch maxi ignition help!!Re: Anthony Sanchez | Anthony Sanchez | 07/05/19 04:13PM |
Re: Puch maxi ignition help!!Re: Overpriced Parts | Overpriced Parts | 07/04/19 04:22PM |
