Blue wire is the one for the condenser, another reason to remove the old one when installing an external condenser (or at least removing the wire from the old one if you have the 3 coil magneto and it is hidden under coil #3).
> ♣Slew Foot♣ Wrote:
> If you do everything and replace the condenser and it's still acts the
> same way there is a blue wire that runs under the point set it gets
> yanked and Baird once in awhile and it will mimic a bad condenser
