Voltage regulator question
I have this voltage regulator
https://www.treatland.tv/trail-tech-voltage-regulator-p/trail-tech-regulator-7003-ac01.htm
When I want to regulate voltage on my 3 main lights, but they’re coming from different lines off stator, is there a place I can put this regulator to protect all lights?
Pa50ii
Re: Voltage regulator question
Dirty30 Dillon /
Plop the regulator in line with the yellow wire coming out of the stator and that should provide regulation for the Headlight (hi/lo) and taillight. The brake lamp should really need it unless you're revving the bike while also trying to brake?
Jason White /
Will give it a shot, thanks
