Re: Clacking sound in rear tranny/variator
Kristian Lomeland /
> DrGeorgeTompson (Alan) Wrote:
> > > Starter clutch?
> > If they were bad, wouldn’t it be difficult to start? It starts super
> > easy, first pull every time.
> eh, if the springs are bad or weak the shoes can bounce off the clutch
> bell, but probably make it easier to start.
> I assume since you rebuilt the gear box, that is good. so it kinda
> leaves the driven pulley/clutch bits. have you looked at the clutch
> itself yet, are the bearings in the rear pulley good? The euro clutches
> have really small posts, they could be bent but i doubt that.
I understand. The driven pulley and clutch in the rear is the only thing I have not replaced anything in. And therefore i have little knowledge about them. The previous owner said that is was some kind of bushing that was causing the clacking noise, but I dont know if that adds up? What bushing could he have been talking about if so?
I will look in to the clutches tonight. Do you have a good way of checking if the clutch springs are good or bad?
