Re: From my stator wattage step down, fuses "how to"
♣Slew Foot♣ /
You get a voltage regulator and a rectifier and you're right it off the stator before it goes anywhere and then you have to have the charging circuit right for the battery I'm sure it can be used as a regulator or a rectifier but have to find out it fell just fry you might need a zener diode or something is this a home project or is it a factory one with a battery if it's a factory one with the battery look at the wiring diagrams
