Re: Minarelli v1 dies when idling
Cleats Onionpockets /
If it's turning over, then it's not clutch/spring related. You might have something up with the fuel/air mixture, especially since you said you needed to adjust the idle speed. You could also have lost some compression without realizing it, as that would definitely affect idle.
