How to I replace the decompression valve
I want to replace the decompression valve but I’m not sure how to. Any advice on how to remove it?
Re: How to I replace the decompression valve
read the wiki under suchs
Why replace it ?
Just clean it and lap it .
Reginald Parris /
I tried lapping it but it’s not staying
What do you mean 'not staying' ?
Reginald Parris /
Tried putting it back together. It would hook then slip off. I’m new to this stuff so I’m learning as I go
the valve has a little slot in the end that clips into the outer part of the valve assembly. so it pulls that center piece out. then the cable goes through, and pinches it together which pushes the valve down in.
