Re: sachs 504 hardwire help
♣Slew Foot♣ /
Easy peasy man the rear original OEM lamps for that AR 3 volt + 2 volt so you could basically just like take apart one of them little LED flashlights and fashion a brake light and a thing off of them use a one that takes a single battery for the running light and use the double for the break cut them up make them as small as you can like their buttons put them right on the fender and you cut them it right angle just wire the positives and leave the housing as the negative ground and they'll work just like tail lights
