Puch E50 clutch bell hitting cover
I have a issue with the clutch bell is making contact with the clutch cover. I’ve removed all shims from behind the bell and it’s still hitting to the point that the clutch is locked up, I set the clutch up by the book Do I need to use more or thicker cover gaskets or ? P.S. the clutch is all stock.
Re: Puch E50 clutch bell hitting cover
cranks walk?
I was thinking the same but I haven't fired it up yet, Full rebuild on it.
I got a few extra cover gaskets to try an shim it out, A 0.8mm and four STD thickness gaskets. I will post the results.
