Vespa Grande electrical issue.
ELLAK MOLNAR /
Brake light works as it should when Brake is applied. However, Headlight and horn do not! Is this a wire issue or light coil issue? I rather not take the time to trace wires if it's the light coil and I have to end up removing the engine to replace a coil. Any suggestions?
Re: Vespa Grande electrical issue.
Check the light coil at the engine for power.
ELLAK MOLNAR /
Just did the Volt check with my handy dandy volt meter and got Zip! Thank you Stephen. Looks like a half days work is ahead removing and replacing the engine to get power to the head lights and a horn. On a bright note, I live in Ohio and it's nothing but rain and flooding around here. So, It will give me something to do until the sun comes around again? Thanks again Buddy.
Not a problem
