Re: Moped runs without spark cap
Den 23 /
> Luc Bordier Wrote:
> ... the ignition timing is set to .015 mm is the gap, and I’m
> running regular 50:1 gasoline mixture, I suspect I have way too
> much compression...
I suspect you are mixing up imperial measurements with metric. What you want your points gap to be is 0.015in. Your stated 0.015mm converts to 0.0006in. This will NOT work. Please recheck your points gap and ignition timing. Remember: Set the gap FIRST then set the timing. If you insist on using metric for setting the points gap then you are looking for 0.38mm. Do you have a 0.38mm feeler gauge?
