Re: Moped runs without spark cap
Stephen Simmons /
> Luc Bordier Wrote:
> Hey Stephen, the igition timing is set to .015 mm is the gap, and I’m
> running regular 50:1 gasoline mixture, I suspect I have way too much
> compression since my cylinder head needs two gaskets or else the piston
> will hit the head, anyone know any good cylinder kits?
.015mm is the gap? Is that the spark plug or points gap?
