FA50 Suzuki won’t stay running
I have a super nice Suzuki fa50, it only ran in choke when I got it , cleaned carb new gas put air box back on it’s clean , it will idle in choke only and snub our when I give it gas ,, I also burned the pipe out ,,, any ideas on air screw or clip settings on the slide needle? Thank you I’m fixing it for someone !! Thank you !!!
Re: FA50 Suzuki won’t stay running
Paul Brassard /
I had the same issue and there is another post on this topic about the petcock.
First you’ve put your gas filter in the vacuum line, so I would try that first.
I actually took apart the petcock, cleaned it and changed an o-ring that was completely dry and broken. This might help making the vacuum. Make sure the diaphram rubber is clean.
As I mentioned earlier there is a post about this issue and someone bypassed the petcock and has it running this way.
Good luck!
Here's the service and owners manuals for free download :
https://drive.google.com/drive/folders/1raDJJQ2M_A8v9lFIxSyYpzRKIRMQ4a1f
The service manual will have the info you need .
If all is stock , follow the instructions , exactly .
It sounds like you may have missed thoroughly cleaning the idle circuit .
