Re: tail light not working brake light does
derek cuellar /
> Mike M Wrote:
> not sure how it is wired on yours but i had a similar issue on a tomos
> and it turned out that the tail light just wasn't hooked up. check to
> make sure everything is hooked up
Yes do this^. Also check to make sure the contact points of the lamp are touching the bulb contact points (both power and ground).
