tail light not working brake light does
my taillight doesn't work but headlight, brakelight and horn does. I changed the bulbs yet no help. did I use the wrong bulb? I have a sachs 505 yard man moto trek
Re: tail light not working brake light does
If only one bulb in the lamp did you use a dual filament bulb?
no there's a spot for two bulbs
not sure how it is wired on yours but i had a similar issue on a tomos and it turned out that the tail light just wasn't hooked up. check to make sure everything is hooked up
derek cuellar /
Yes do this^. Also check to make sure the contact points of the lamp are touching the bulb contact points (both power and ground).
