bypassing general ignition switch
Hi all,
New to this forum, just got my first project moped a 1985 general.
From what I can tell the keyed ignition switch is broken. If I were to cut this out, could I bypass it by simply connecting the two wires that run into it, or is there more complexity to it?
This is the lock: https://www.lucky2strokes.com/General-Lazer-Moped-Fork-Lock-p/general-fork-lock-x26.htm
Re: bypassing general ignition switch
Blake Totally a real doctor /
I have new old stock ones with the wires attached if you just want to replace it.
From memory, you should just be able remove the lock and connect the wires. I believe pulling the key breaks the ground circuit. Or it's the opposite but its only 2 wires so simple to test. It's been a little bit since I've worked on a General. (edited)
Hi Blakea
Do you happen to still have some new old stock fork locks for general 5/Lazer?
Jeff
> jeff forty wrote:
> Hi Blakea
> 5/Lazer?
> Jeff
I just picked up a 1980 General 5 star ST and its missing the keys and ignition switch. Would appreciate a pm if you have one for sale. Thanks!
Beach Club Nick /
> Joe Berns wrote:
> > jeff forty wrote:
> > Hi Blakea
> > 5/Lazer?
> > Jeff
> Thanks!
The dude was asking for one, he didn't have keys for sale...
