Cylinder head
Hi, this cast cylinder head I believe was in a thread earlier. I understand the outside doesn’t matter much. But I’m concerned about in inside wall, should I have it machined out or hand sand or get a replacement?
Re: Cylinder head
Well,if you can get a replacement, do it. Meantime you might be able to get that one bored to an oversized kit.
Re: Cylinder head
I might have a good one if you need one.
Re: Cylinder head
Dirty30 Dillon /
That cylinder is toast. By the time you hone it clean it will be 4 sizes too big.
DOS Cycles has the cylinder you seek.
Re: Cylinder head
Thanks Don, I'm going to keep it stock, for now. 8) PM d you Stephen. (edited)
Re: Cylinder head
Also, that is not a cylinder head.
Re: Cylinder head
To complete that^ : what you have pictured is simply a cylinder .
A head would be the unit that 'caps' the cylinder .
Re: Cylinder head
Slangily called a `jug'. But we knew what he meant...…...no harm.
Re: Cylinder head
Les, Treats has a 50cc stock kit by kstar. It's completely stock and 50 bucks. I have one and it's good.
Buuuuttt.... The 50cc DR kit is much more exciting and still 50cc. I highly recommend it.
