First start knocking sound
<iframe src="https://www.facebook.com/plugins/video.php?href=https%3A%2F%2Fwww.facebook.com%2Fthefloorisguava%2Fvideos%2F10156066328411109%2F&show_text=0&width=476"; width="476" height="476" style="border:none;overflow:hidden" scrolling="no" frameborder="0" allowTransparency="true" allowFullScreen="true"></iframe>
This doesn't sound normal, is this the piston hitting the head? Do I need to space it out? I built this a few years ago but this is the first time it's ever started, give me some time to backtrack what setup I have.
Re: First start knocking sound
Sounds like something in the transmission to me.
Chöschi21 C.K. /
Is that just when cold? if so it might be the cylinder
Pull the plug and insert a length of solder . Enough to reach the cylinder wall . Then crank the motor a few full revolutions while holding the solder firm in one place .
Pull the solder out and measure the end section . That should tell you if the piston is hitting the head and give an idea of squish .
