Pick up coil 2 wire, mod into 1 wire
I was wondering if anyone knew how ?
Re: Pick up coil 2 wire, mod into 1 wire
What color are the wires?
This needs way more info.
I assume you mean the CDI. Typically there are 2 types, 2 wire being that it has a pickup coil and a power coil, the power builds charge and the pickup sends the timing trigger.
Alternately you have 1 wire which uses the flip in polarity of the magnets in the flywheel as the trigger for timing. Things like if your flywheel's got 4 magnets vs 2 all affect timing.
Also the CDI boxes (and HT coil if it's one piece, as many are) are not interchangeable. In theory you might be able to do it just by switching the CDI box to one which accept the "1 wire" timing signal, and then setting the timing without the woodruff key, but there are alotta variables that could make that not work
The short answer though, swap the stator, flywheel and CDI box to a 1 wire setup.
