'79 Mobylette 50v no spark
Danny LaChapelle /
Hey everyone, new here with my first bike i picked up as a project. My headlight comes on when cranking pedals and i know some things are working, but i believe my coil may be open/shorted? I'm reading 3.4k ohms from just the external coil and 5.4k ohms from just the spark wire. Does that sound right or is something wrong? Visual inspection I'm not able to see a spark when the plug is out and the pedals are cranking. Thanks in advance.
Re: '79 Mobylette 50v no spark
not sure about those numbers, but i like to chect for continuity between coil terminal n cap. cracks in the coil r bad sign, might help to add a ground between coil mount and head bolt and ground plug for testing
Danny LaChapelle /
I have a ground from my coil mount to a head bolt, but I'll check for some cracks in the coil
