Qt50 speedometer gone wild
Has any qt50 owners ever had a speedometer go hay wire and had the needle jump all around while making a high screeching noise?
Re: Qt50 speedometer gone wild
Lube the cable . If that doesn't fix it , flip the speedo up side down and apply a light oil to the drive and let it sit over night , re-apply oil .
And check for hardened up grease in the front wheel hub before it strips the plastic drive gear. That probably wouldn't be the noise but it could be the death of speedo operation.
Thanks guys, cable is lubed, I will try flipping Speedometer upside down
