Re: Just when you thought you'd seen it all
live ɘvil /
> Jack Rutherford Wrote:
> Yeah I screwed up. Why? Probably because the collar was fused to the
> crankshaft on every other one that I've done. This was the first one
> where the collar actually came right off. And that collar actually
> serves as a spacer for the primary drive gear. So I had to take it
> apart and do it again with the collar and the correct seal. Anyhow,
> let's hope I don't get fooled again!
Where did you obtain the correct seal from? Ive been able to take bearings and seals to local bearing shops in the midwest and obtain the correct replacements 95% of the time for a fraction of what oem cost.
