Re: Just when you thought you'd seen it all
Geoff L /
Hi Jack, I just posted a question about this seal and collar. How did you make out with the installation of the seal? My question is when putting the new seal in, is there a particular order to follow? For example, should I put the seal into the case and then the collar into the seal, using the beveled edge as the guide? I already wrecked a new seal trying to put it over the collar when the collar was already on the shaft. Also, did you install this seal dry or with a sealant on the outside?
