Starting issues with Tomos
Well I checked the carb and switched the jet, that was all clear, jets had no blockages. The carb had gas in it when I took it apart, checked the fuel line, it was clear. Put it all back together and tightened the throttle cable, PoS still won't start. So next it's check the compression, the ignition and sparkplug system to see if that's the issue. If not I'm lost and it's going to a mechanic.
Re: Starting issues with Tomos
Moped needs fuel, spark, compression to start. Figure out which it’s missing and narrow it down
diy
♣Slew Foot♣ /
Did you choke it when you tried to start it if not do so hold the front brake in then if it doesn't start disconnect the kill switch try it again no spark it's either the box er coil. Check your intake also for leaks while you're at it if you take it apart and put it back together then correctly you can check the reeds hopefully you see the wiki up top and use it accordingly
