1980 puch maxi. 5k miles.
Starts/idles and runs fine from a cold start. After about a mile of ripping i lose power. it still idles but i lose almost all acceleration, it bogs if I throttle too much. I know I've got a small air leak in the top of the bing(gasket on the way). After I nurse it back to the garage and shut it down with the kill switch, it doesn't want to start again. When I pull the plug after a bunch of kick it's barely wet. If I put some fuel into the cylinder it will fire. I've pulled the carb apart a couple time and it's clean. I recently down jetted to 61 after I was getting 4 stroking with 65. So to me it's some sort of intermittent fuel issue but I don't know how to isolate that. Maybe a bottle and bypass the tank? Any help troubleshooting this is appreciated
current setup
14mm bing
61 jet
212a atomizer
stock metal mesh airbox
circuit pipe
stock 50cc
needle at 2nd from bottom (edited)
