I just found out I have an air leak at the exhaust. I've never seen the copper gasket style before. Is copper a good enough gasket material? Does it require replacement often due to its soft nature? Expansion and contraction? What are your experiences? Winters here get really cold in the -15 range too. I always have to check for leaks on my puch in the spring because things loosen up.
