Um...
Will this work? I've gone through three seals and this is the best I've got it... I'm not too good at this.. please check it out..
Re: Um...
looks compromised. b4 u attempt no 4 seal, bevel the case a bit so it dont hang up...., clean, take off washer. Add tape on the crank so that shoulder dont stop/tweek the seal. grease inside, motoseal outside of seal and tap in gently, evenly.
Re: Um...
So the way it is now won't work??
Re: Um...
If it were me...if the inner lip was not messed up, and it was just the outer, I would gob a little moto seal on the dinged up part and run it. If it doesnt work, try again with a new seal. If it works, well then you saved some trouble. Got nothin to lose.
Re: Um...
Thank you. I'll try it and see what happens
