1977 Puch Bogs After Stops
Tyler Durphine /
Hello.
Having an issue with my '77 Puch (parts below).
70cc treat KIT
70cc hi hi compression head
Tecno BOSS performance pipe
5 dellorto main jets - 80s range
5 dellorto main jets - 90s range
Dellorto PHBG 21mm carburetor
Malossi E12 air filter
19mm PHBG piston port intake
Engine bearings and seals
BLUE hi tension clutch springs
E50 case allen bolts set
Super stuffy racer crankshaft
Domino grips
Giuliari black TWO SEATER
Passenger pegs
Rear shocks
Gold chain for both sides
Brake pads
Magura brake lever bolts
All Cables
Tubes and tires (sava MC1)
Spark plug and spark plug boot
Center stand kit
EBR BLACK maxi forks WITH stabilizer + reinforced top plate
MLM Reinforced swing arm
Forks headset bearing set
Headlight
Petock, fuel line, and filter
17 tooth front sprocket, 41 tooth rear sprocket (comes with original 45t as well)
Trail tech temp gauge and mount
I've cleaned everything top to bottom, found no air leaks, new gapped plug etc.
Bike starts on single kick, idles perfect, rides well and can reach 45mph normally. However any time I come to a stop light or sign and have to sit for a minute, it bogs terrible and can hardly accelerate off the line. Makes riding traffic extremely difficult.
I am going to take apart my carb again, but recently just did so and seemed to be in good order. Am I correct to assume the idle screw / mix screw on the carb wouldn't really matter in the situation or should I mess with them more?
I believe my jets are good. I ran many, many miles before on this set up and never had an issue.
Re: 1977 Puch Bogs After Stops
If you raise your idle does this fix the problem.
My Puch idles at nearly 2k
