Re: QT50 - Ignition/Starting
Coleman Gavel /
So I took that white plastic piece off that the key turns to make contact, and now I can't get it to go back how I had it. Battery is good, fuse is good, all the wires are good. If I start it, and put the plastic piece back on, it will kill it. Which it only does that when the contact hits the two gray wires that are soldered to one contact. I took the tumblers out and it will turn with no key, I just want it to make it look like you need a key. Any suggestions?
  QT50 - Ignition/StartingTopic by: Coleman Gavel Coleman Gavel 05/23/19 09:29PM
  Re: QT50 - Ignition/StartingRe: Mac Patten Mac Patten 05/23/19 10:14PM
  Re: QT50 - Ignition/StartingRe: Jack Rutherford Jack Rutherford 05/24/19 11:21AM
  Re: QT50 - Ignition/StartingRe: Stephen Keller Stephen Keller 05/23/19 10:23PM
  Re: QT50 - Ignition/StartingRe: Mac Patten Mac Patten 05/23/19 10:34PM
  Re: QT50 - Ignition/StartingRe: Mark B****** Mark B****** 05/23/19 10:45PM
  Re: QT50 - Ignition/StartingRe: Coleman Gavel Coleman Gavel 05/24/19 11:02AM
  Re: QT50 - Ignition/StartingRe: Jack Rutherford Jack Rutherford 05/24/19 11:24AM
  Re: QT50 - Ignition/StartingRe: Coleman Gavel Coleman Gavel 05/24/19 03:06PM
  Re: QT50 - Ignition/StartingRe: Jack Rutherford Jack Rutherford 05/24/19 10:08PM
  Re: QT50 - Ignition/StartingRe: Coleman Gavel Coleman Gavel 05/24/19 10:16PM
  Re: QT50 - Ignition/StartingRe: Coleman Gavel Coleman Gavel 05/25/19 10:34AM
  Re: QT50 - Ignition/StartingRe: Coleman Gavel Coleman Gavel 05/25/19 01:30PM
  Re: QT50 - Ignition/StartingRe: Jack Rutherford Jack Rutherford 05/25/19 02:55PM
  Re: QT50 - Ignition/StartingRe: Mac Patten Mac Patten 05/25/19 03:40PM
  Re: QT50 - Ignition/StartingRe: Mac Patten Mac Patten 05/27/19 01:16PM
  Re: QT50 - Ignition/StartingRe: Coleman Gavel Coleman Gavel 05/29/19 08:49PM
  Re: QT50 - Ignition/StartingRe: Coleman Gavel Coleman Gavel 05/30/19 09:24PM
  Re: QT50 - Ignition/StartingRe: Mac Patten Mac Patten 05/30/19 09:35PM
  Re: QT50 - Ignition/StartingRe: Coleman Gavel Coleman Gavel 06/07/19 06:39PM
  Re: QT50 - Ignition/StartingRe: Keno Rojas Keno Rojas 06/07/19 06:50PM
  Re: QT50 - Ignition/StartingRe: Coleman Gavel Coleman Gavel 06/07/19 07:42PM
