Re: QT50 - Ignition/Starting
Mac Patten /
On the 84 I had, I ended cutting and splicing in a used MJ50 ignition key switch into the harness. Mine was three position, though. Different wires soldered to the contacts on the original. I could not find on a generic one with the same. The brown is turn signal/horn , grey is oil light, if I remember right. Red and black with red stipe wires are your start circuit, black is ground.
Make sure to get a 6v relay. I had to hunt for awhile find any yamaha switch (qt50/mj50/whatever else) that was similar.
If anything, you can try pushing out the pins of the female connector and rearrange them in the correct order to match your new switch. May or may not work, but that saves you from have to splice.
  QT50 - Ignition/StartingTopic by: Coleman Gavel Coleman Gavel 05/23/19 09:29PM
  Re: QT50 - Ignition/StartingRe: Mac Patten Mac Patten 05/23/19 10:14PM
  Re: QT50 - Ignition/StartingRe: Jack Rutherford Jack Rutherford 05/24/19 11:21AM
  Re: QT50 - Ignition/StartingRe: Stephen Keller Stephen Keller 05/23/19 10:23PM
  Re: QT50 - Ignition/StartingRe: Mac Patten Mac Patten 05/23/19 10:34PM
  Re: QT50 - Ignition/StartingRe: Mark B****** Mark B****** 05/23/19 10:45PM
  Re: QT50 - Ignition/StartingRe: Coleman Gavel Coleman Gavel 05/24/19 11:02AM
  Re: QT50 - Ignition/StartingRe: Jack Rutherford Jack Rutherford 05/24/19 11:24AM
  Re: QT50 - Ignition/StartingRe: Coleman Gavel Coleman Gavel 05/24/19 03:06PM
  Re: QT50 - Ignition/StartingRe: Jack Rutherford Jack Rutherford 05/24/19 10:08PM
  Re: QT50 - Ignition/StartingRe: Coleman Gavel Coleman Gavel 05/24/19 10:16PM
  Re: QT50 - Ignition/StartingRe: Coleman Gavel Coleman Gavel 05/25/19 10:34AM
  Re: QT50 - Ignition/StartingRe: Coleman Gavel Coleman Gavel 05/25/19 01:30PM
  Re: QT50 - Ignition/StartingRe: Jack Rutherford Jack Rutherford 05/25/19 02:55PM
  Re: QT50 - Ignition/StartingRe: Mac Patten Mac Patten 05/25/19 03:40PM
  Re: QT50 - Ignition/StartingRe: Mac Patten Mac Patten 05/27/19 01:16PM
  Re: QT50 - Ignition/StartingRe: Coleman Gavel Coleman Gavel 05/29/19 08:49PM
  Re: QT50 - Ignition/StartingRe: Coleman Gavel Coleman Gavel 05/30/19 09:24PM
  Re: QT50 - Ignition/StartingRe: Mac Patten Mac Patten 05/30/19 09:35PM
  Re: QT50 - Ignition/StartingRe: Coleman Gavel Coleman Gavel 06/07/19 06:39PM
  Re: QT50 - Ignition/StartingRe: Keno Rojas Keno Rojas 06/07/19 06:50PM
  Re: QT50 - Ignition/StartingRe: Coleman Gavel Coleman Gavel 06/07/19 07:42PM
