My tomos Lx has a delorto carb 14/12. Recently I replaced the throttle cable but my moped either is at full throttle or it doesn’t throttle at all when I put everything together.
I believe that the problem is that the spring is restricting the slide from going up and down. If I took off the spring would that fix this issue?
