Loose crank bearing seat..
Quick question....if one of your crank bearing seats in the case has sloppy tolerance to the outer race of the bearing, so that the crank has a bit of end float and you can feel it rocking ever so slightly up and down, are the cases effed? Or can you slather some loctite on the outer race of the bearing to take it up?
this is on a tomos .
Re: Loose crank bearing seat..
Probably Fred /
bushing adhesive! there are many types
Google it
♣Slew Foot♣ /
Unbalanced clutch stick some Teflon tape in it and call it done or just do it right and buy another case app what it's like 40 bucks
