Re: Yamaha qt50
Mark B****** /
Take your ohm meter and read the black wire w/red stripe off the stator. Its a single plug, should be near your ignition coil. Check the resistance on that wire to ground, should be over 300 ohms. If its not then you have a bad charge coil.
