Starting my first V1 project
Buddy Shirey /
After finally "finishing" my first moped build, I'm ready to move on to a 76' Intramotor Gloria Blanco that I picked up for $100 a little over a year ago. It's been sitting in my shed until I could get my daily rider back on the road. Depending on how things go it may become my daily rider as I'm getting a little tired of the 2 speed tomos trans and I've really enjoyed riding my friend's V1 powered gaddabout and safari. I'm ready to ride a single speed for a while.
It's got some issues but it's 95% there. It's only missing the fan, shroud, and tail-light lens. Whoever had it before the guy I bought it from definitely left it out in the rain or something. It's got a fair amount of rust and for whatever reason they removed the nuts from the cylinder head and then just left it. So the inside of the cylinder is rusted to the piston and stuck. Advice on how to get this unstuck would be appreciated.
I was thinking put some PB blaster down the cylinder, tighten the head back down and then turn the crank using a wrench on the flywheel. If anyone has a better idea I'd love to hear it. Crank spins but the cylinder slides up and down the studs with it. The piston and cylinder are now one.
Once I get that off I plan on doing a full rebuild following this guide.
Once it's rebuilt i plan on putting a polini kit on it and more than likely an SHA 15 with matching intake. If I go bigger than that I'll probably use PHBG 19 as I've never messed with mikuni and I've built up quite the collection of dellorto jets over the last couple years. Suggestions on what might give me the best results are welcome.
As far as what pipe i'll go with, it'll probably either be the new MLM proma circuit, zen, or possibly the derbi big muff pipe that dos sells. A friend of mine suggested the last one saying that it should be pretty easy to make it work since it's got the swivel exhaust flange. It's the most affordable of the options I listed so if others think it'll work I will probably go that route.
Before i do any of that though, i want to get the frame rolling and solid. First thing is cleaning the tank as it's definitely got some rust. Next thing I'd like to do is replace those swinger forks. I've heard of people swapping in tomos forks on these frames and was thinking that's what I'd do since I have an extra set or two around. Is this an easy swap where all I'd need to change is the headset or is it a little more involved?
If indeed it is as simple as swapping headsets I'll probably go ahead and do that this weekend so i can move on to other things. I don't mind having to get creative to make something work but I'd like to avoid having to mod the frame if at all possible. I also have a set of hobbit forks available.
I'll be switching the ignition to pietcard CDI. This seems like it's pretty straightforward but i'll add questions later if I have any issues once i get around to that.
I'll be replacing all the cables, brake pads, bulbs etc but again that stuff is all pretty straightforward and i doubt I'll have much trouble with it.
Lastly ( for now ) , if i'm swapping out the front fork I assume I'll no longer be able to use the original front wheel. Since i'm thinking tomos forks, I'll probably run a tomos mag on the front end. I like my wheels to match so how hard is it to make a tomos wheel work on a blanco swing arm? I made a 17" rear snowflake off of a garelli ( I think) fit on a tomos so why can't I make 16" rear tomos mag fit on a blanco? That being said, if it's not very feasible i'll just find a tomos spoke for the front and keep the original rear wheel so they'll still match at least aesthetically.
I've read the v1 rebuild wiki quite a few times and i feel comfortable enough to attempt a rebuild with just that info. I'll probably print it out and keep it nearby on the bench when i actually start it just to be safe.
That's about it for now. If anyone has any tips or tricks for getting this frame and/or engine broken down I'm all ears.
