> J D Wrote:
> I'm working on the same issue, same CDI on another Moby. I was going to
> run the yellow wire through the rectifier (for DC LED lighting and a DC
> klaxon type horn) and ground everything to the chassis. Glad I saw your
> thread before I got too far along and looking forward to a solution
> specific to the same setup that I've got, short of running ground wires
> all over the place.
> Thoughts?
If you want to ground your lights to the frame you can only use a half wave rectifier.
That means you only get half the voltage. No bueno. The best way is to isolate the DC system like I've shown.
Here is example of the half wave. As far as I know, you can only use full wave if you have an independent ground, like shown in my diagram with the "floated DC".
I will post a full wave rectifier diagram here later.
(edited)
