> Mike Boyd Wrote:
> Yup! I'm just bad at explaining it using the proper terminology :)
No way, great explanation. I just re-read your earlier one and now it makes sense. I forgot you posted this :
> Yeah typically if a coil only has one wire lead, it means the grounding
> lead is soldered directly to the coil mount on the stator. One way to
> bypass or "float" this is to unsolder that lead from the mount and
> solder a length of wire to it so you can run it to the DC system
