> Mike Boyd Wrote:
> > Francois Labat Wrote:
> > Guys,
> > The le partie stator only has one yellow wire for "lights".
> > The trail tech rectifier has 2 yellow wires for stator input. How do I
> > get two yellow wires connected? Is this what people mean by floating
> the
> > stator?
> Yeah typically if a coil only has one wire lead, it means the grounding
> lead is soldered directly to the coil mount on the stator. One way to
> bypass or "float" this is to unsolder that lead from the mount and
> solder a length of wire to it so you can run it to the DC system
Damn, that seems like a lot of work using the trail tech honestly.
I have a feeling using a rectifier, then a regulator sounds easier at this point.
