> Francois Labat Wrote:
> Guys,
> The le partie stator only has one yellow wire for "lights".
> The trail tech rectifier has 2 yellow wires for stator input. How do I
> get two yellow wires connected? Is this what people mean by floating the
> stator?
Yeah typically if a coil only has one wire lead, it means the grounding lead is soldered directly to the coil mount on the stator. One way to bypass or "float" this is to unsolder that lead from the mount and solder a length of wire to it so you can run it to the DC system
