> Aaron Blair Wrote:
> The first diagram has the newly rectified DC separate from the frame.
> Thus the red and black wires for POS and neg. Ur diagram would have DC
> and ac from the coil grounded to the frame at the same time.
Good point, didn't realize that. I guess, does it need to be separate is the question.
You're also correct, the Vapor gauge can take 4-400 Vac or Vdc. I will most likely power it with the rectified DC, keep it consistent.
Also, don't confuse, I'm showing the trail tech rectifier, not the gauge on my diagram. I need to ad that still.
