Hello everyone.
I've been digging through the posts here to get a game plan for my wiring. I've seen a lot of great posts but there are a couple questions I cannot find the answer to. This will be an ongoing thread as I update this wiring diagram.
My goal is to use the Le Partie CDI and trail tech rectifier to power LED front and Rear lights and Trail Tech Vapor Gauge.
Parts:
Trail Tech Rectifier / Voltage Regulator
I saw a post where someone uses the red and black battery leads from the trail tech to power their system.
The 3 initial questions I have are :
1.) Can I use the red and yellow wire from the trail tech to power both front and rear lights? Why use the system above?
2.) Do the grounds for the kill switch, and light switches all have to route back to the main frame point I've chosen?
3.) The trail tech rectifier has 2 yellow wires for "stator", I believe Le Partie only has 1 yellow Ac wire. Do I join the two rectifier yellows to the 1 yellow stator wire?
Here is the start to my diagram:
Thanks (edited)
