Moby Wiring (CDI, LED, Recftifier)
Hello everyone.
I've been digging through the posts here to get a game plan for my wiring. I've seen a lot of great posts but there are a couple questions I cannot find the answer to. This will be an ongoing thread as I update this wiring diagram.
My goal is to use the Le Partie CDI and trail tech rectifier to power LED front and Rear lights and Trail Tech Vapor Gauge.
Parts:
Trail Tech Rectifier / Voltage Regulator
Trail Tech Vapor
I saw a post where someone uses the red and black battery leads from the trail tech to power their system.
The 3 initial questions I have are :
1.) Can I use the red and yellow wire from the trail tech to power both front and rear lights? Why use the system above?
2.) Do the grounds for the kill switch, and light switches all have to route back to the main frame point I've chosen?
3.) The trail tech rectifier has 2 yellow wires for "stator", I believe Le Partie only has 1 yellow Ac wire. Do I join the two rectifier yellows to the 1 yellow stator wire?
Here is the start to my diagram:
Thanks (edited)
Re: Moby Wiring (CDI, LED, Recftifier)
The first diagram has the newly rectified DC separate from the frame. Thus the red and black wires for POS and neg. Ur diagram would have DC and ac from the coil grounded to the frame at the same time.
My bad, Let me elaborate..ur going to need to isolate the dc from the frame. or maybe there's a way to isolate the sparky bits from the frame....If I were you, I would use the rectifier for the trail tech and just buy rectified ac/DC LEDs.
Wait, does the trail tech even require DC?
I could be completely dumb here, but it seems like they need to be separated.
French Moby /
Good point, didn't realize that. I guess, does it need to be separate is the question.
You're also correct, the Vapor gauge can take 4-400 Vac or Vdc. I will most likely power it with the rectified DC, keep it consistent.
Also, don't confuse, I'm showing the trail tech rectifier, not the gauge on my diagram. I need to ad that still.
French Moby /
I think theres two ways of doing this like you said:
1.)Create a DC system with the rectifier using the red and black wires with capacitor.(they were designed to charge a battery)
2.)Create a DC system using the red/yellow wire, and ground to frame.
I'm a mechanical engineer and circuits was a dreadful class for me. I was speaking to my buddy who's in electronics and it seems like we couldn't find an issue with this until I read the trail tech paperwork. I wanted to use the red/yellow wire as + to accessories, and ground the black to frame, with the AC ground. The documents say not to though.
EDIT: Is it because grounding AC to frame, and grounding trailtech DC to frame could cause AC to go up DC ground?
(edited)
French Moby /
Okay another update, I hate how there's a time limit to edits.
I will be using the red/yellow as my positive and the black trail tech wire as my ground. My accessories will not be grounded to frame, they will be grounded on a block, with my trail tech ground
I think that's what I'll go with.
yay! glad you figured something out. i think that those caps are in there to smooth the pulses of dc more than anything. whats that called clipping? lust like an across the line cap in an audio amp.
wow, good for you. always wanted to go to college for EE.
French Moby /
Guys,
The le partie stator only has one yellow wire for "lights".
The trail tech rectifier has 2 yellow wires for stator input. How do I get two yellow wires connected? Is this what people mean by floating the stator?
> Francois Labat Wrote:
> Guys,
> stator?
Yeah typically if a coil only has one wire lead, it means the grounding lead is soldered directly to the coil mount on the stator. One way to bypass or "float" this is to unsolder that lead from the mount and solder a length of wire to it so you can run it to the DC system
French Moby /
> > Guys,
> the
> > stator?
Damn, that seems like a lot of work using the trail tech honestly.
I have a feeling using a rectifier, then a regulator sounds easier at this point.
With the coils I've "floated" it was pretty simple! Just used a razor to pry off the grounded end then some solder and shrink wrap. And I suck at soldering. But I hear ya...
French Moby /
Who has actually used a trailtech rectifier here?
I called trail tech and hes telling me since they use a "shunt" you have to use a capacitor as a load, or a battery.
Anyone that's used a trail tech, PLEASE tell me how you wired it.
Thank you.
French Moby /
I think I'm slowing understanding the system.
The trail tech requires the AC+ and AC- from the stator. The Le Partie CDI yellow wire is the AC+ and the other wire is grounded somewhere on the stator. So I need to remove that grounded wire and extend it to the trail tech rectifier.
Yup! I'm just bad at explaining it using the proper terminology :)
French Moby /
No way, great explanation. I just re-read your earlier one and now it makes sense. I forgot you posted this :
French Moby /
Okay I drew a few different wiring scenarios that I will share here once I'm confident. I understand how "floating" the lighting coil works now. Just experimenting with other crap.
I'm really hoping that once I'm done with all this I can dumb it down so much, anyone reading this thread will come out with a good understanding.
There will be two electrical circuits on the moped.
One for all the ignition crap
One for all the accessories
One of those will be AC and the other will be DC.
I was trying to mess around and instead of "floating" the lighting coil, use the frame as ground and ground my lights but I can't think of how that would work.
I'm working on the same issue, same CDI on another Moby. I was going to run the yellow wire through the rectifier (for DC LED lighting and a DC klaxon type horn) and ground everything to the chassis. Glad I saw your thread before I got too far along and looking forward to a solution specific to the same setup that I've got, short of running ground wires all over the place.
I did find a couple of similar threads/info on other sites, talking about getting rid of the floating ground:
https://advrider.com/f/threads/regulator-rectifier-wiring.1321804/ (<-- bottom of the page, from "Beezer")
http://www.karlstrommotor.se/upload/PDF/EMX/trailtech_regulator_beskrivning.pdf
(a LOT more wires and such but same principal. Also talks about the Trail Tech regulator, if that is specific to your task at hand)
If my spatial reasoning skills and ohm-meter are correct, this (red lead) would be where the end of the lighting coil is grounded. It appears to be opposite of where the existing yellow wire is grounded. Physically that is, not sure how they different electrically because my meter says they're all connected. BThere are two solder lugs on the opposite (facing from of the bike) side of the bobbin. But they also connect to ground when I ring it out so this assessment is based more on physical location, rather than electrical characteristics.
Thoughts?
French Moby /
> all over the place.
> Thoughts?
I spent a few hours last night drawing different wiring diagrams until it made sense. The drawings are all over the place so once I'm off work here, I plan to draw 2 diagrams. One stock wiring diagram, and one diagram for Le Partie CDI with Trail Tech. I'll make it clear and simple. Will post later tonight. Should answer your questions
.... existing yellow wire is CONNECTED (sorry)
Awesome, thanks
French Moby /
Okay first off:
The reason you can't connect just one wire from stator to rectifier is because AC current goes back and fourth. Technically it goes up and down with the sine wave. If you connect one wire, you will only get half the voltage rectified. Because half the sine wave will enter the rectifier, but the other half will go towards the frame, since the other wire is grounded there. This stuff is confusing. Unless someone on here can recommend how to use frame ground, I would stick to what I'm showing you below.
Notice the two circuits circled
You can see that you have created an independent DC circuit for all the stuff you want to power! The rest stays AC to the frame.
These drawings are simplified. But I hope the big picture makes sense.
Here is how your wiring should look like now that we've understood why this person has wired their moped this way.
Let me know if I can improve this post. I will now be working on my own wiring diagram but it will prob look like the one above.
French Moby /
I notice my image says (+) current and it's technically wrong but the red wire is the "hot wire". Too lazy to change it.
French Moby /
> all over the place.
> Thoughts?
If you want to ground your lights to the frame you can only use a half wave rectifier.
That means you only get half the voltage. No bueno. The best way is to isolate the DC system like I've shown.
Here is example of the half wave. As far as I know, you can only use full wave if you have an independent ground, like shown in my diagram with the "floated DC".
I will post a full wave rectifier diagram here later.
(edited)
Was hoping that ID'ing the coil ends would present a more robust solution. Think I'll follow the recommendation on AC/DC LEDs. More wires makes more opportunities for trouble later. Also takes up more room/cramped. Not sure what all the Vapor does but seems like a lot of effort for an accessory. But you've got it so go for it. Biggest problem for me would be figuring out how to isolate all the light sockets once I had a DC and GND line run to each since I'm using stock fixtures and sockets, otherwise they would still see the AC ground through their connection to the chassis. May be super simple but I think it will be self regulated/rectified bulbs for me.
WRT voltages and such, I don't think that it would be "half" the voltage (as in volts) but half the frequency. Not 100% on magnetos but (seems like) freq is likely dependant on engine speed so more flicker at idle. It didn't look like the coil can center tapped so you get what you get as far as output voltage goes. I ran a sim in one of those online circuit sims and it seemed like it would be a (relatively) fast cycle, even at idle speeds. That's just a sim though, not real world. Even if the rest of the world didn't notice, I'd know. Probably wear out lights faster as well, but just another (slightly) educated guess on my part. You basically already have a 1/2 wave with just the LED but they are more sensitive to voltage fluctuation than a regular silicone switching diode.
**Edit: I also ran a sim with a full wave rectifier and it kept failing with an over current/short in the diode bridge.
I think that using a 1/2 wave rectifier, maybe an in-line diode, you'd still probably want a regulator. Like you said, stuff is complicated, but putting the negative AC on ground would create some additional problems as now your ground and rectified voltages are constantly at varying differences in potential. Not sure how much a regulator would do to help with that but at least it's a measure that could be implemented. Then again, that could be 100 incorrect. Just thinking it out in my head. Maybe some additional noise from the ignition since it is on the same ground? Now I'm just throwing out random stuff.
The .PDF that I posted the link for (second link) is for installation of the Trail Tech voltage rectifier/reg on a bike. The instructions weren't very verbose but then again, maybe they figure it just works without explaining all the theory behind it.
Hope that your solution works out for you. Good Luck and post some more pics once you've got it put together! (edited)
French Moby /
> diode.
Thanks man!
You should see what my moped looks like right now... It's just a freshly painted frame. I'm into this thing so deep, I can't see anything as extra work anymore haha.
I'm happy with using the trail tech rectifier since it has good reviews and the wiring will be simple. I don't mind running grounds back to the DC ground. Also, just because my headlight is mounted to the frame, as long as the electrical connections AKA wires or light leads don't touch the frame it's fine. So mounting the headlight to the forks like stock should not be an issue i dont think.
Honestly though, I really wanted to just reuse all the stock wiring, but I'm in too deep now haha.
I'll post back in here with updates. Front and rear LED. Should be bright. For me I think this system will be more worthwhile than the AC Led combo lights.
