Re: Leaky tranny on chain and wheel
Overpriced Parts /
> Brandon Weiss (Detective brandon to you) Wrote:
> > Buddy Shirey Wrote:
> > Never used an estoril but biturbo's are pretty loud so i wouldn't be
> > surprised.
> > strap wrench looks something like this
> https://www.zoro.com/ridgid-strap-24-in-32020/i/G5385947/feature-product?gclid=EAIaIQobChMI3uOb5vOd4gIVnLXACh1aZgYcEAQYASABEgLDI_D_BwE
> > Put the strap around your magneto and use it to hold the crank into
> > place while you remove the nut holding your clutch bell on.
> > Most people recommend this as it keeps you from pressing your piston
> up
> > against anything and risking damaging it in any way. If you do end up
> > buying a piston stop get the extra long one that treats sells. That's
> > what I use and haven't broken anything yet while using it. You do have
> > to be a little more careful though when you go this route.
> > Basically when you try to remove the nut holding on your clutch bell
> > you'll end up just spinning the crankshaft and never be able to loosen
> > the nut unless you use one of the methods I listed above.
> > Using a strap wrench is not only the safest method but you can
> probably
> > get one locally without having to get it shipped to you.
> You should only use a strap wrench on the same side of the crankshaft
> that youre working on. Otherwise youre putting torsion on the crank and
> thats no good.
> Either use rope or a piston stop for the clutch side, because you can't
> hold the crank with a strap wrench on that side.
You don’t even need a piston stop, and it’s not good to use one either because it will damage bearings and wrist pin/crack piston at wrist pin, leave the top end on, one zip with impact and I’ll come right off, the crane will barely even move
  Leaky tranny on chain and wheelTopic by: Terry Dorman Terry Dorman 05/14/19 10:58AM
  Re: Leaky tranny on chain and wheelRe: todd amundson todd amundson 05/14/19 11:04AM
  Re: Leaky tranny on chain and wheelRe: Moped Lar (OFMC) Moped Lar (OFMC) 05/14/19 11:08AM
  Re: Leaky tranny on chain and wheelRe: Terry Dorman Terry Dorman 05/14/19 11:36AM
  Re: Leaky tranny on chain and wheelRe: Terry Dorman Terry Dorman 05/14/19 11:46AM
  Re: Leaky tranny on chain and wheelRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 05/14/19 03:36PM
  Re: Leaky tranny on chain and wheelRe: EH FCC of the QCB EH FCC of the QCB 05/14/19 04:16PM
  Re: Leaky tranny on chain and wheelRe: Born to be WillD Born to be WillD 05/15/19 09:39AM
  Re: Leaky tranny on chain and wheelRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 05/15/19 11:01AM
  Re: Leaky tranny on chain and wheelRe: Terry Dorman Terry Dorman 05/14/19 06:35PM
  Re: Leaky tranny on chain and wheelRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 05/14/19 07:29PM
  Re: Leaky tranny on chain and wheelRe: Terry Dorman Terry Dorman 05/14/19 10:34PM
  Re: Leaky tranny on chain and wheelRe: Aaron Blair Aaron Blair 05/14/19 10:39PM
  Re: Leaky tranny on chain and wheelRe: Terry Dorman Terry Dorman 05/15/19 09:56AM
  Re: Leaky tranny on chain and wheelRe: Moped Lar (OFMC) Moped Lar (OFMC) 05/15/19 10:40AM
  Re: Leaky tranny on chain and wheelRe: Buddy Shirey Buddy Shirey 05/15/19 11:13AM
  Re: Leaky tranny on chain and wheelRe: Terry Dorman Terry Dorman 05/15/19 11:53AM
  Re: Leaky tranny on chain and wheelRe: Buddy Shirey Buddy Shirey 05/15/19 12:10PM
  Re: Leaky tranny on chain and wheelRe: Terry Dorman Terry Dorman 05/17/19 09:52AM
  Re: Leaky tranny on chain and wheelRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 05/17/19 12:15PM
  Re: Leaky tranny on chain and wheelRe: Overpriced Parts Overpriced Parts 05/17/19 03:38PM
