Re: Leaky tranny on chain and wheel
> Buddy Shirey Wrote:
> Never used an estoril but biturbo's are pretty loud so i wouldn't be
> surprised.
> strap wrench looks something like this
> https://www.zoro.com/ridgid-strap-24-in-32020/i/G5385947/feature-product?gclid=EAIaIQobChMI3uOb5vOd4gIVnLXACh1aZgYcEAQYASABEgLDI_D_BwE
> Put the strap around your magneto and use it to hold the crank into
> place while you remove the nut holding your clutch bell on.
> Most people recommend this as it keeps you from pressing your piston up
> against anything and risking damaging it in any way. If you do end up
> buying a piston stop get the extra long one that treats sells. That's
> what I use and haven't broken anything yet while using it. You do have
> to be a little more careful though when you go this route.
> Basically when you try to remove the nut holding on your clutch bell
> you'll end up just spinning the crankshaft and never be able to loosen
> the nut unless you use one of the methods I listed above.
> Using a strap wrench is not only the safest method but you can probably
> get one locally without having to get it shipped to you.
You should only use a strap wrench on the same side of the crankshaft that youre working on. Otherwise youre putting torsion on the crank and thats no good.
Either use rope or a piston stop for the clutch side, because you can't hold the crank with a strap wrench on that side.
  Leaky tranny on chain and wheelTopic by: Terry Dorman Terry Dorman 05/14/19 10:58AM
  Re: Leaky tranny on chain and wheelRe: todd amundson todd amundson 05/14/19 11:04AM
  Re: Leaky tranny on chain and wheelRe: Moped Lar (OFMC) Moped Lar (OFMC) 05/14/19 11:08AM
  Re: Leaky tranny on chain and wheelRe: Terry Dorman Terry Dorman 05/14/19 11:36AM
  Re: Leaky tranny on chain and wheelRe: Terry Dorman Terry Dorman 05/14/19 11:46AM
  Re: Leaky tranny on chain and wheelRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 05/14/19 03:36PM
  Re: Leaky tranny on chain and wheelRe: EH FCC of the QCB EH FCC of the QCB 05/14/19 04:16PM
  Re: Leaky tranny on chain and wheelRe: Born to be WillD Born to be WillD 05/15/19 09:39AM
  Re: Leaky tranny on chain and wheelRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 05/15/19 11:01AM
  Re: Leaky tranny on chain and wheelRe: Terry Dorman Terry Dorman 05/14/19 06:35PM
  Re: Leaky tranny on chain and wheelRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 05/14/19 07:29PM
  Re: Leaky tranny on chain and wheelRe: Terry Dorman Terry Dorman 05/14/19 10:34PM
  Re: Leaky tranny on chain and wheelRe: Aaron Blair Aaron Blair 05/14/19 10:39PM
  Re: Leaky tranny on chain and wheelRe: Terry Dorman Terry Dorman 05/15/19 09:56AM
  Re: Leaky tranny on chain and wheelRe: Moped Lar (OFMC) Moped Lar (OFMC) 05/15/19 10:40AM
  Re: Leaky tranny on chain and wheelRe: Buddy Shirey Buddy Shirey 05/15/19 11:13AM
  Re: Leaky tranny on chain and wheelRe: Terry Dorman Terry Dorman 05/15/19 11:53AM
  Re: Leaky tranny on chain and wheelRe: Buddy Shirey Buddy Shirey 05/15/19 12:10PM
  Re: Leaky tranny on chain and wheelRe: Terry Dorman Terry Dorman 05/17/19 09:52AM
  Re: Leaky tranny on chain and wheelRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 05/17/19 12:15PM
  Re: Leaky tranny on chain and wheelRe: Overpriced Parts Overpriced Parts 05/17/19 03:38PM
