Hey all,
I have the Mike Thomas aluminum hub and 5 star setup on my maxi. Was curious if anyone had any clever ways to get a VDO or other speedometer drive to fit.
Thanks for any help,
-Garrett-
Hey all,
-Garrett-
if theres a spacer on the axle you should be able to dremel out a slot for the tab on a speedo drive. as long as you can get the drive stationary and the tab spinning in time with the wheel it'll work. some adjustment needed for wheel size etc but I think you should be able to make it work with come clever spacing.
