Re: 85' Maxi "wiring woes"
Kenneth Hill /
What if I replaced the 6v bulbs with 12v of the same wattge? Or install a 6v regulator? I personally like the 12v option better as the lights would be brighter at speed. Any "clues" about the convoluted brake light wiring would be appreciated as well. Maybe the blue/green power wire is there to have the brake lights on dimly at all times, and then when the power from the green coil output is added they come on much brighter? (edited)
